C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
EFILive Question
Old Nov 15, 2011 | 08:25 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default EFILive Question
I haven't heard back from EFI Forum - thought I would ask here -
Restricted to: Personal Scan&Tune (no cable) ???
I can't get the cable connection to work - does the above "(no cable)" mean I am wasting my time?
I have tried reloading the com drivers - both kinds - and either it will crash the laptop or it will not recognize a cable connection !!
Getting very frustrated!!
Old Nov 15, 2011 | 08:52 AM
edcmat-l1's Avatar
edcmat-l1
Have you went to your device manager and made sure it's assigned to the right comm port?
Old Nov 15, 2011 | 10:03 AM
1stGlance's Avatar
1stGlance
PM'd
I will try to check the com port assignment - but nowhere does it tell you what com port to use - if you can only use one? It doesn't load the driver initially - until the USB cable is connected from the FlashScan V2 device - far as I can tell. So when you plug it in - on whatever com port - it loads the driver - at least that is what I have observed so far?
Thanks for the reply !!
Old Nov 15, 2011 | 11:02 AM
edcmat-l1's Avatar
edcmat-l1
PM'd
If it's recognizing it when you plug it in, and self installing the driver, that sounds like it's working correctly.
Does it complete the driver install, and give you the dialog box which says so? Then what do you do, and what does it say?
Old Nov 15, 2011 | 01:38 PM
1stGlance's Avatar
1stGlance
I checked that it appears and has the proper Device Instance path in the Device Manager. • FlashScan V2: USB\VID_0403&PID_E4A1\FSV2
However non of the EFILve modules recognize the FlashScan - keeps telling me "no cable"....
The FlashScan V2 is connected to the laptop and has a menu screen showing on the device - but I can't get the software to recognize it...
Old Nov 15, 2011 | 07:45 PM
jeff keyuk's Avatar
jeff keyuk
When I had trouble with mine, There a guy in L.A. ,He was one of the guys who wrote the scan tool. www.Fishtuning.com There is some little thing you are doing wrong!
Old Nov 19, 2011 | 12:11 PM
1stGlance's Avatar
1stGlance
Default Looks like
We will need to try another FlashScan V2 unit...
after the tech folks at EFILive determined there was nothing wrong in the setup configurations.
Old Nov 20, 2011 | 09:23 AM
jeff keyuk's Avatar
jeff keyuk
same as mine.sent my old one to fish,he sent me back a new one.
Old Nov 24, 2011 | 01:11 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The OBDII port has a fuse---If the fuse is blown you will get a "no cable"--or " no device" message--- GM hides the fuse--it's the cigarette lighter fuse----Many times with cell chargers and alike this fuse blows--
Old Nov 25, 2011 | 01:00 AM
KCvetteowner's Avatar
KCvetteowner
OP, if you have any more problems, come by our shop (814 Motorsports) and we will get it going for you...
To EFILive Question
