C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Codes
Old Mar 1, 2012 | 04:32 PM
homeless's Avatar
homeless
Default Codes
Guys need your help my 03 z it was throwing a code tcs c1233 hc rf wheel speed circuit open-shorted.So i called the chevy dealer to buy the wheel speed sensor extension harness,he had to order it. He told me to switch the left and right harness to make sure it was the harness,so i did. Now i have 3 codes so i switched them back,still 3 codes tried to clear them but no luck tcs c1232 hc tcs c1233 hc tcs c1248 hc What should i do next THANKS
Old Mar 4, 2012 | 12:53 PM
sunchaser73's Avatar
sunchaser73
Do you have access to the service manual or alldata? If not, pm me with your email address and I can send you the guides for each DTC you are experiencing.
Also...are you sure it is C1248?...I ask because I looked it up and can find no such code.
Old Mar 4, 2012 | 05:09 PM
homeless's Avatar
homeless
Thanks but i do have a list of the codes,but i was like you could not find c1248. But after goggle help i found several guys wanting to know and from what i found it is low brake fluid. I have orderd both harness'ss so maybe this will fix it.I really do THANK YOU for wanting to help.
Old Mar 7, 2012 | 07:28 PM
homeless's Avatar
homeless
I put both harness's on today car still showing tcs 1233 hc,any idea's
To Codes
