C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Check Engine Light
Old Sep 25, 2012 | 12:55 PM
joseibbo's Avatar
joseibbo
7th Gear
Default Check Engine Light
I found a possible solution by searching the code in this Forum. I will try the suggestions and report back soon.
I have a 2000 C5. My mechanic has replaced the gas cap, the fuel tank sensor and the engine sensor but is still getting the same code. He said the code was PO440 for an evaporative sensor problem. Has anybody had the same problem?
Old Sep 25, 2012 | 04:24 PM
Z06Brucey's Avatar
Z06Brucey
Begin a Vette tech if you don't know the code its kind of hard to tell you what direction to head in...
Old Sep 26, 2012 | 03:46 PM
joseibbo's Avatar
joseibbo
7th Gear
Default C5 problem
He said the code was PO440.
Old Oct 16, 2012 | 09:09 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Here is a recc. diagnostics for code P0440
Its raher technical but most evap codes can be pesky to trace ohther than the fuel cap--
IF you think the car is running the same regardless---Alast resort would to have a tuner permantly DELETE all the EVAP codes and they will never re-appear
http://www.gearchatter.com/viewtopic10341.php
To Check Engine Light
