C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Can HP tuners program RPO codes
Old Dec 3, 2012 | 06:55 PM
superjet701k's Avatar
superjet701k
Default Can HP tuners program RPO codes
Will a hp tuner be able to shut off my F45 option . I switch to Z06 shocks and now I'm limited to 80 mph and ride control inop. I'm going to the Dyno on wed. I know a tech two can do it but I don't have access to one here in Cape Coral FL
Old Dec 3, 2012 | 11:17 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I don't think so--I know EFILIVE won't--I believe you will need a TECH II to disable the
F45 ---Anyone know about using the Tech II for this ???
Old Jan 10, 2013 | 08:43 PM
littlefranks's Avatar
littlefranks
you need a tech 2 ,remove rpo out of bcm,you have to unplug unit in back of storge compartment.
Old Jan 11, 2013 | 10:39 AM
02402ramair's Avatar
02402ramair
You can do the resistor mod also. Very easy and cheap too.
To Can HP tuners program RPO codes
