C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
O2 sensor extensions
Old Jun 8, 2013 | 06:21 PM
RAS6582's Avatar
RAS6582
Default O2 sensor extensions
I recently installed long-tube headers and had to make extensions for the O2 sensors. Now it is throwing a code. I read that it is not good to splice the wires because it will skew the reading. Also you cannot solder. I have tried everything I know to do and still no luck. I'm at my wits end and need any help or advice.
Old Jun 11, 2013 | 05:13 PM
jeff keyuk's Avatar
jeff keyuk
That's a big No No! Summit racing sell o2 wire extensions ,made by casper !!Car needs to be tuned with headers ,back 02 can't come up to temp!
Old Jun 14, 2013 | 07:43 PM
RAS6582's Avatar
RAS6582
I forgot to mention that the car has been tuned and the rear O2 sensor codes have been deleted from the pcm. I had to make extensions for the engine-monitoring O2 sensors. When I installed the headers the harness got melted and I had to splice the wires. I had it tuned and then 6 months later this code was set which was strange to me because it worked fine for 6 months. I'm kind of wondering if I have it wired right.
Old Jun 15, 2013 | 05:35 AM
jeff keyuk's Avatar
jeff keyuk
What codes are coming up.
Old Jun 15, 2013 | 10:36 AM
RAS6582's Avatar
RAS6582
P0134 and P0155. I just realized that the fuse has blown for the O2 sensor circuit so I replaced it but it will probably blow again. I guess I have a short somewhere.
Old Jun 15, 2013 | 02:57 PM
RAS6582's Avatar
RAS6582
I repaired the harness side with a part # J-38125-B and maybe I have it wired wrong. I tried to mirror the side that wasn't damaged but I'm unsure if I have it correct. Does anyone know the pin and wire color for this? It is the front O2 sensor for a C5.
Old Jun 15, 2013 | 08:58 PM
danieloneil01's Avatar
danieloneil01
You think it might be wired wrong 6 months later after you get a code for the first time? You sure a wire isn't loose?
To O2 sensor extensions
