ABS/Traction Control Lights on Dash....Any Help?
Hello, I've recently acquired a 1999 coupe. The ABS and traction control lights are on, on the dash. After doing a code check I'm getting (28-TCS) C1232 C and 1233 C. Also, (BO-RFA) U1016 HC and C2110 C. Are any of these related to the above mentioned dash lights and what can I do to fix these, without having to take it into the dealer? Thank you in advance for any help.
St. Jude Donor '13-'14-'15
The ABS braking system and the traction control systems both use data from the 'wheel speed sensors' located at each wheel---The ECM uses the data to control wheel spin via the TC and to control wheel skidding on a hard stop via the ABS--
Typically a random warning light can be FALSE triggered by driving on a rough road or over railroad tracks--- disconnecting the battery should reset it back to normal---If it happens again and you haven't driven over the above mentioned things then you may indeed have a problem--But even then it can be a dirty or fouled wheel speed sensor pigtail caused by water or simply time---
