C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help "reduce engine mode" pulled codes
Old Feb 14, 2014 | 02:23 PM
c5hifive's Avatar
c5hifive
2nd Gear
Default Help "reduce engine mode" pulled codes
Hey guys I bought a 1999 corvette and i new it had a few problems but now it's stuck in reduce engine power mode, and when you turn key on ac the dash and lights flicker, also it doesn't always turn dash on you have to turn the key on back and forth a bunch of times for it to initialize
I've check under the battery for leaks and nothig
Also checked throttle body connectors for corrosion and nothing major but I cleaned em, computer is also clean
The car is a 1999 convertible ls1 with Texas speed heads, cam, cold air intake, borla exhaust and so I'm told it's EFI live tuned so plz suggestion how to get it out of this mode
Here are the codes
P1332
P1222 hc
C1278 c
B0333 hc
B0338 hc
B0446 h
B0032 hc
P1221 hc
P1120 hc
B0502 hc
Old Feb 14, 2014 | 02:51 PM
c5hifive's Avatar
c5hifive
2nd Gear
Plz help guys I really don't wanna take it to a shop so any help is much appareciated
Old Feb 14, 2014 | 04:56 PM
c31980's Avatar
c31980
this may help
http://www.stengel.net/diccodes.htm
Old Feb 14, 2014 | 07:45 PM
Sids04's Avatar
Sids04
Half those codes are not listed... The valid ones point to TPS.. Throttle position sensor.. I'd replace it and reset the CEL..
Old Mar 17, 2014 | 02:11 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The only codes that would put it into a "limp mode" are the P codes-----you can look all of the P codes at htttp://gearchatter.com
They describe how to fixes of usual codes----T-body codes especially will put the car into reduced power mode-Immediate fix is to start and shut off the engine 3 times--and that will reset the reduced power mode--tempolarally -----But if they reappear---or it oes into limp mode report back with the codes gain
Old Mar 17, 2014 | 08:46 PM
cguth's Avatar
cguth
Sounds like you have exceded max aiflow table. You can adjust the table with hp tuners.
To Help "reduce engine mode" pulled codes
