C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
command lockup
Old May 31, 2014 | 04:59 PM
sams96's Avatar
sams96
Default command lockup
using hpt what is the process to command lockup ih 4th?
Old May 31, 2014 | 05:49 PM
78GEN3's Avatar
78GEN3
Do you mean while using the scanner?
Old May 31, 2014 | 05:54 PM
sams96's Avatar
sams96
yes, i hit tcc solenoid is that what im suppose to click
Old Jun 1, 2014 | 04:24 PM
78GEN3's Avatar
78GEN3
Yes, that should do it.
You can add "TCC Mode" to the display table to get feedback while using the controls.
Old Jul 4, 2014 | 02:39 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Just curious why you would want to data log the 4 th gear lockup--All lockups are commanded by 2 things throttle position [B]and MPH----Look at your tune to see what is the commanded lock up in 5th say at 20% tps---and see if it indeeds shifts there--Lock up apply speeds are easy to diagnose---The onlt]y times the commaned lock-up speed won't match the actual is if the 3-4 shift speed is to close to the 4th gear lock up--
Either they will happen both simostainiously or the 4th lockup will be delayed by 5-8 MPH after the 3-4 shift
To command lockup
