C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Idle Quality on A4 Stroker Engine?
Old Jul 24, 2002 | 08:46 AM
Tom Hall's Avatar
Tom Hall
Default Idle Quality on A4 Stroker Engine?
The question is, why is the idle so hard to tune on an A4, but the same engine in a M6 idles fine? Their must be some programing changes in the PCM that LS1 Edit does not Address at this time. I talked to Wade (ARE) about this and we both would like to know the answer.
I have seen the GM program and their are Thousands of sections and only a few that the Edit covers. I know the LS1 Edit will get much better in time.
So, any input on this, feel free to jump in.
Old Jul 24, 2002 | 09:49 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: Idle Quality on A4 Stroker Engine? (Tom Hall)
This statement is not at all encouraging... :(
I hope so. I would very much like to see the gear scaling fixed. :)
Can you describe when you feel the idle becomes difficult to tune?
Old Jul 24, 2002 | 12:34 PM
Corvette4ever's Avatar
Corvette4ever
Iam not sure. The engine is the same, the only difference would be the drivetrain. I bet the torque converters in A4 has something to do with it.
Old Jul 24, 2002 | 09:49 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In III Veteran
The latest Beta of LS1Edit has additional gear scaling (addresses all issues I have had), and two additional idle tables which address the IAC control issues I've been waiting for....
Old Jul 26, 2002 | 10:19 AM
RWhite's Avatar
RWhite
Default Re: Idle Quality on A4 Stroker Engine? (nevrenuf)
I know that when I had my 3500 Vigilante installed, the idle was about 100 rpm's lower and it even died one time when I went around a corner. The idle seemed to be hunting for a resting place when I came off the throttle, going between 450 and 600, up and down.
We eventually solved it by upping the idle using LS1_Edit and what I think really helped, doing the simple idle relearn procedure. That, I think, eventually settled everything down. Now, it idles at 650 rpms, no wandering, just like stock. Maybe it was only the relearn procedure that did it.
To Idle Quality on A4 Stroker Engine?
