C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Incorrect MAP
Old Jan 12, 2015 | 11:08 AM
Blow Torch's Avatar
Blow Torch
Default Incorrect MAP
I have been working on other tuning issues, so I haven't spent much time digging into this, but anyone have an idea why my map readings in my scans are topping out around 120-123
I thought at first it might be some belt slip or maybe a leak (I have a flip drive, and I have everything tight) but the car has INSANE power (for 3lbs of boost) and I just glanced up at the in car boost gauge (while trying to keep the car straight in second gear LOL) and saw it pass 8lbs (and still revving)
By the power its making, it has to be 10+ and it SHOULD be around 12-14 based on the pulley I'm running.
Any thoughts?
Old Mar 7, 2015 | 02:58 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Did you figure this out? If not, turn your key on (no start) and start data logging. If the reding isn't around 100-101 kPa then you have a problem.
Old Mar 7, 2015 | 11:28 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
With key on and no start the KPA should be atmospheric pressure as stated---100 KPA
A normally aspirated engine at WOT goes atmospheric and should have a 100KPA reading as well
Your engine being boosted will go over atmospheric at WOT and exceed 100 KPA
A 123 KPA reading would equal boost of 23 KPA
23 KPA is a PSI boost of only 3.35
This is obviously WRONG--- a KPA reading of 155 would equal 8 PSI of boost
To Incorrect MAP
