C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
p1635
Old Mar 31, 2015 | 08:54 PM
maxjett's Avatar
maxjett
Default p1635
Got the engine back in the car was running perfect now it is idling rough and has p1635 also notice the oil pressure gauge says at 50psi even when engine is not running any ideas
Old Apr 7, 2015 | 04:21 AM
RonSSNova's Avatar
RonSSNova
You likely have a short circuit in the wires to the MAP sensor. Which of course is on the back side of the intake manifold.
There are 3 leads. Ground, output and 5v.
That code says there is an issue with the 5v.
It's always helpful for us if you would provide the code description when posting so we don't have to go look it up.
Ron
