C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Injector Adjustment???
Old May 2, 2015 | 11:42 AM
Galler's Avatar
Galler
Default Injector Adjustment???
Hey, last summer I had to replace my oil sender unit. As I was putting it all back together I cracked a few injector and it hasn't run the same sense. I have new injectors but I went with bigger injectors as I will eventually be upgrading heads can etc. this will be down the road a little ways yet. My question is,
Do I need to have the new 42# injectors duty cycles adjusted so the vehicle doesn't run rich, or will the PCM handle this?
Old May 2, 2015 | 01:02 PM
umrjmac's Avatar
umrjmac
You'll have to have the tune adjusted to run different injectors. The values defining the injectors are the foundation of the fuel model.
FWIW it isn't adjusting the duty cycle...duty cycle is a function of how much fuel is actually being delivered (derived from measured/calculated air mass, computation for target Lambda/AFR, then delivery based on the fuel model). Your tuner should change a number of tables that define the injectors.
Old May 4, 2015 | 12:13 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
When changing injector flow rates the only way to correct the fuel is to make the appropriate adjustment to your IFR table---otherwise a larger injector will make it run RICH
Also LS1 injectors are rated at 54 PSI most aftermarket ones are rated at 43 PSI---make sure you calibrate your new ones at 54 PSI or 4 bar-----
If you have stock ls1 28 lb injectors they are fine for up to 500 crank HP so no need to change---- a 42 LB injector which is a standard aftermarket mod is actually about a 48 lb injector on a LS1 system---way to big for a N/A engine
Old May 4, 2015 | 10:01 AM
enoniam's Avatar
enoniam
You can likely run the 42# injectors if you already have them, but as noted your tune needs to be adjusted.
I just replaced my 289,000 mile truck's blown 5.3 with a crate normally aspirated 6.0 that is supposedly good for 460 crank hp. Less fuel pressure than tblu noted above in that application so your mileage will vary, but as a reference point I'm getting a max duty cycle in that engine with the 42# injectors of about 60%.
Old May 4, 2015 | 10:14 AM
umrjmac's Avatar
umrjmac
Also, just to expand on it, there's a LOT that needs to be adjusted beyond just the injector flow rate to do it right. If you only change the flow rate your low pulse behavior will not line up with what you're telling the computer it will do...your tuner ends up bandaiding the tune by jacking around with the air model to correct for it.
Some things that may need adjustment:
Minimum pulse width
Default pulse width
Short pulse limit
Short pulse adder vs effective pulse width
Injector offset vs injpw vs map
Offset vs manifold vacuum vs vbat or offset vs differential fuel pressure or offset vs volts
Flow vs manifold vacuum or flow vs differential fuel pressure
I don't have HPTuners installed on my work laptop so I can't see which are correct for a genIII PCM, but the list actually changed should be a subset of what I listed above.
Old May 4, 2015 | 11:57 PM
tblu92's Avatar
tblu92
Minimum pulse width
Default pulse width
Short pulse limit
I agree--- When installing huge injectors it allows for peak HP at WOT--however the P/T drivability and idle suffers--because the large injectors with stock tuning cannot command a small enough pulse--If you already have the 42's use them-- but a tuner will need to make several adjustments to help the P/T idle fueling---The best route is to get injectors as small as you can to accommodate you max HP level but still keeping the duty cycles below 80-85% at WOT---On a manual trans there is more room for error and it's more forgiving- but with an automatic drivability issues can arise
To Injector Adjustment???
