C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Methanol questions
Old Oct 14, 2015 | 06:50 PM
goombadi99's Avatar
goombadi99
Default Methanol questions
On average how much more horsepower could be expected from adding meth injection? I only put down 460 with a ecs kit and am hoping to be closer to 500rwhp.
Old Oct 14, 2015 | 10:21 PM
jcblade's Avatar
jcblade
Can't tell you with meth only but when I added headers and meth to the ECS supercharger, I gained 50hp.
Old Oct 15, 2015 | 12:03 AM
StingrayRebel's Avatar
StingrayRebel
I would guess around 50 and maybe a little more depending on how aggressive the tune is... meth is not necessarily what is adding the power but the added octane allows the tuner to add more timing without detonation so the end result is more power... this is assuming that you are using it for the purpose of making more power and your tune is meth dependent... if you are using it only as a safety measure then you might not gain anything at all
Old Oct 15, 2015 | 12:45 AM
goombadi99's Avatar
goombadi99
I already have headers on the car from the supercharger install. I'm hoping the tuner can add at least 3 or 4 more degrees of timing.
Old Oct 15, 2015 | 12:52 AM
StingrayRebel
if you haven't already done so, pull the restrictor plate and that will get you at least a couple more pounds of boost... with that and the addition of meth you should easily hit your goal
Old Oct 15, 2015 | 06:53 AM
goombadi99's Avatar
goombadi99
Yeah but the engine is not forged. Pulling the restrictor plate plate and the engine probably won't last very long. Lol
Old Oct 15, 2015 | 09:34 AM
StingrayRebel
you will be fine if it's tuned properly
To Methanol questions
