C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
LS1 Edit ?
Old Aug 27, 2002 | 01:24 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default LS1 Edit ?
will it overwrite a powerloaded PCM ? :confused:
Old Aug 27, 2002 | 10:15 AM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: LS1 Edit ? (MRWHOOPPEE)
I do not know for sure but I have read elsewhere on this forum that it will not.
Old Aug 27, 2002 | 10:48 AM
ToplessTexan's Avatar
ToplessTexan
The older your Powerloader is, the more likely you won't have a problem. The more recent, say maybe this year or late last year, the probability of trouble is much higher. Easiest thing to do in that case is to reflash the PCM as you would with a new one and go from there. Have a look at the service manual's description of PCM R&R.
To LS1 Edit ?
