C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help needed
Old Dec 19, 2015 | 10:50 AM
triple black vette's Avatar
triple black vette
Default Help needed
Hi fellas, I have a question for you fellas with tuning experience who can help me with a issue I have with my 02 zo6. It has a ls3 now with a very street able comp cam and street tuned. Everything else is stock. I recently bought a scanner to the check sensors and found the LT FTRM1 (%) @ 2.3 @ idle and drops to 0.0 with light throttle, the LT FTRM2 (%) @ 0.0
ST FTRM1 (%) @ -2.3
ST FTRM2 (%) @ 0.8
ST FTRM11 (%) @ -2.3
ST FTRM21 (%) @ 0.0
Upstream o2 sensors switching between 100-800v normally.
Downstream 02's stay around mid to high 700's and steady.
Now for my question. Does the LT FTRM1 (%) indicate a rich condition ? If so where ?
I've checked for vacuum leaks but found nune. I'm leaning more towards a bad injector.
Old Dec 19, 2015 | 11:31 PM
RonSSNova's Avatar
RonSSNova
With numbers that small, you have nothing to worry about.
Even 5% doesn't indicate a problem.
There is +/- 25% range available.
I'd say it's quite happy!
Ron
Old Dec 19, 2015 | 11:57 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Never worry about or even log the STFT's as they are no help in tuning-----Only the LTFT's should be of any concern-----As Ron said any LTFT that is below = or- 5% is of NO concern----as your ECM has the ability to eventually "learn out" these fuel trims and finally settle at "0"
FYI a positive LTFT fuel trim at P/T means the ECM is adding fuel for a LEAN condition
a negative LTFT fuel trim at P/T means the ECM is removing fuel for a RICH
condition
AT WOT the 02's are NOT being used--HOWEVER if you have a positive LTFT at P/T that same % is also added at WOT as a lean safety and can make your WOT rich
BUT if you have a negative LTFT at P/T the ECM will NEVER remove fuel at WOT and locks on "0" again as a lean safety
Old Dec 20, 2015 | 08:16 PM
triple black vette
Thanks for your help guys, it was very informative.
Old Dec 21, 2015 | 03:01 AM
RonSSNova's Avatar
RonSSNova
Any time!
To Help needed
