Should I put my Stock MAF ends back on before I start with LS1-Edit?
I keep hearing people say that they went back to the stock MAF (no screen) and their car pulled like an animal. I kinda felt that the MAFT/Breathless Ends with Air FOil did the same for me... But hey I'll try it if it works......
I think I will go back to stock before I start my LS1-Edit Tuning.
any opinions?
any opinions?
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (chuckster)
That's what I was told by "my tuner," so that's what I did. Ditched the Vortex for a BW also. I never liked the way the "Air Foils" wiggled when installed anyway, nor the fact that two holes were misaligned and had to be redrilled and half the holes were countersunk on the INSIDE and the stock screws did not work and ... manufacturer said they would have to see it to comment (on the inside countersinking, etc.) no thanks
any opinions?
any opinions?
IMHO tuners hate MAF ends because they have developed their tuning around stock ends and don't want to take the time (read $) to accomodate the change. Yes, it is a pain to recalibrate the MAF properly, we're on custom program #7 for my car, but that's also part of the fun of modding.
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (6Speeder)
I would put your stock ends back in. Maf ends are not a restriction. They cause a car to gain power because the mis-calibration causes a lean condition.
The only upgrade I will do to my MAF will be an 02 z06 maf, and then I'd put in the 02 z06 maf table.
Eric
Eric
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (66ImpalaLT1)
Like bolting a ported and/or larger TB onto our intakes, not necessary.
Good thing about removing the nylon one's is that you can sell them!
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (Stu in CA)
I took my Breathless MAF ends off prior to tuning so I don't know the answer...I did jump from 317rwhp to 337.7 when we were done on the dyno! It took 6 runs, and the A/F of 12.2-12.3 seemed to produce the most HP for us. If anyone wants the BPP ends w/foil I'll sell mine for $100. :cheers: Final#'s after LS1 edit tuneing with the mods listed below: 337.7 rwhp, 342.5 rwtq. I'm a happy camper! :D :cheers:
Since you'll be remapping the MAF table anyway, I'd just keep the ported ones on there. I did.
Ok, nobody has given me a concrete answer why to go back to stock. Let's assume the MAF is calibrated perfectly with LS1-Edit...Why not keep the MAF ends? They are nylon so no heat soak...I can only think of all positive things...
1 Post
Cruise-In II Veteran
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (ToplessTexan)
So how do you plan to do this?
Or you can just take the average LTFT # and multiply the entire MAF curve by some factor using the average LTFT, but I didn't think that was precise enough.
1 Post
Re: Should I put my Stock MAF ends back on before I start with LS1-Edit? (akw408)
I'm thinking a bench is both easier and more accurate. I shouldn't need to have the sensor anywhere near a car to cal it. ;) It's great if you got good results, really, but I would have a hard time calling that a cal.
1 Post
I will say that relying on LTFT, a vector with rather large variation among elements, as an indirect variable is only valid if you believe that the dominant source of variation in it is due to the MAF signal.
I'm still not clear how Charlie was planning on doing this.
I guess I am looking to clarify what people mean when they say use the term 'calibrate.' In my case I mean either a) adjusting or b) interpreting a sensor's signal such that it accuately and reproducibly respresents the measured quantity, in this case air flow. As soon as we start talking about fuel trims I think we've stopped talking about calibrating the MAF sensor.
The only reason I care about a faithful MAF signal (and the reason most tuners are quite happy with a stock sensor) is that everything under the sun in the PCM code seems to use calculated load as an independent variable. Manipulating the underlying signal in response to only one of the dependent variables is likely to have undesireable, unanticipated, and/or unknown effect on other dependent variables.
[Modified by ToplessTexan, 7:13 AM 9/24/2002]
So far I have heard put the "stock back on" and "leave the ported ends on"
But...Nobody here has actually said they have seen an increase in performance using the Ported ends (recalibrated by whatever means) Most of the positive posts come from going back to stock...
Boy, If I get $100 for my ported ends and $125 for my MAFT...my LS1-Edit only cost me $325 ;)
So in short...I think that I will put the stock ends back on for the Velocity gain alone...I will start my tuning from there...
Hmm did I actually make a decision here? :D
Yup, sounds like you did. That was my decision. My tuner said no gains to be had from the ends, but I did recoup $100! :lol:
Kurt, you may have a great point here...Part of the problem I see here is this...The Stock MAF obviously generates a higher velocity. This in turn may actually help fill those pesky cylinders in the rear.
And I'm not convinced higher velocity really matters before the intake manifold. If it did, why do huge honking intake filters and ported throttle bodies help?
Actually The mere physics of it tell you that the velocity does increase. Let's use idle for the example...Since the same volume of air is going through the engine at 750 rpms that is our reference point. Lets say the air going through the stock maf is traveling at X. If you made the MAF 2 times the size then the velocity would be significantly less.
And since the air has a direct shot straight into the intake plenum then it stands to reason that the velocity may help get to those rear cylinders...
I may polish my MAF Ends in the meantime... Man that sounded dirty...:D :lol:
Anyway, this is not worth getting into a huge debate over. Fact is you will probably not notice any SOTP difference. :cheers:
