C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
c5 camshaft position sensor ohm value
Old Apr 3, 2017 | 12:22 AM
greenfinale's Avatar
greenfinale
2nd Gear
Default c5 camshaft position sensor ohm value
need to know the resistance/ohm reading value
Old Apr 6, 2017 | 01:13 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I don't know if there are any published cam position sensor OHM values
Either you get a code for a cam/crank position error or you don't Most tuners just to be safe will do a " crank position relearn procedure" when changing cams---This re learn will position the sensor immediately Someone with HP or EFILIVE can do this relearn for you --- but also anyone with a TECH II can do the same re-learn
Typically if you are NOT getting any codes--you don't need a relearn
