HPT modifications theory only
I dont know if anyone has played around with their products. Every product I get I like to open them up and play around with it, coming from a tech background.
Here is my conclusion for modifying an HPT standard box.
Let me start off by telling you I have not done this and I will not because I dont want to ruin my box. lol. If you want to try please share afterwards
I dont have a pro version to compare the boards. If you can get a snapshot and post it that would be great.
If you open the board up and see the board itself its self explanatory in making it a "pro" version. You would have to modify the cover, get an 8pin screw terminal, and solder it on the board where you see the open 8 pin points.
Now I do not know if you need additional connections like jumpers or what not to make it work on the board itself. I have not tested it with a multi-meter to see if the open points are reading anything. If it does it should work.
Let me know your thoughts.
8-pin screw terminal
HPT board
HPT board
