Corvette 98 Pcm swap issue
Hello guys, i am Gery from Austria and i need help for my swap. I just swapped a 411 Pcm in my Vette. I used the 1998 and 2002 pinout plan for the Job.
I can`t connect the following wires to a new home:
Red connector 98: pin 24, pin41, pin42, pin46, pin69
Blue connector 98: pin 24
I doublecheck everything twice and fired it up.
It starts immediately but after around 10 seconds the engine stops to run.
I get the following fault Messages everytime: P1571, C1277
sometimes the DIC shows this too: U1064, U1016
The fuel gauge shows low but the tank is full.
Engine spec: 427 Ls3, 52Lbs Injectors, Killer Bee 2 Airfilter with Ls3 Maf , 102 Nick Williams TB, 102 Fast Intake, 180 Thermostat, LG 1 7/8 long Tube Headers with high flow Cats, Lingenfelter fuel pump, Dewitt Radiator
Maybe someone who did the same Job can help me?
Double check your pins. Mine is working as I did that last week. see my thread
I did have to disable some DTC. I'm playing around with fuel gauge trying out the express van parameter. I'm using hptuners.
