C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
TPS voltages
Old Feb 28, 2018 | 06:37 PM
busta's Avatar
busta
Default TPS voltages
Chasing a no start issue and I thought I was on to something. I don't have 5volts at my TPS sensor on PIN F (pink wire)
Anyone with 02 vette? Can you measure 5volts on PIN F. I have 5 Volts on the others that are highlighted.
0 Volts PINK wire
Old Apr 18, 2018 | 02:09 AM
HPS MASTER TECH's Avatar
HPS MASTER TECH
at WOT you should have 5 volts there
Old Apr 18, 2018 | 06:30 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
A simple way to check and see if your DBY throttle is working is to remove the entire air tube assembly from the T-Body forward
Have someone in the car turn the key on and floor the throttle to WOT----Then You look into the T-body and see if it is fact WOT-----This should be your 1st check then move onto checking the voltages as described earlier
To TPS voltages
By Michael S. Palmer | 2026-06-03 09:39:05
