C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Jet programmer
Old Mar 16, 2018 | 11:31 PM
tigertank's Avatar
tigertank
Default Jet programmer
The car I just bought 2003 06 came with a jet program or a typical little Box that you have 3 different levels are they any good I'm used to the predators but never heard or seen these
Old Mar 17, 2018 | 01:33 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Almost all handheld programmers are simply vanilla generic programs They simply suck!! A real enthusiast will opt for a real tune with HP or EFILIVE tuning
These are far superior A handheld tuner maybe changes 10 of the 700 tables in your tune
A real tune using HP or EFILIVE will alter about 150 tables !!! Including on a auto trans an electronic shift kit and shift point and TCC lockup correction Trans tuning alone can make most any c5/c6 about 4-5 tenths quicker in the 1/4 mile without even addressing any engine tuning---Typically you can get maybe 10-18 RWHP with engine tuning on any Corvette
The greatest advantage with real tuning is deleting the TQ MANAGEMENT and the WOT delays Stock tuning does NOT allow the throttle body to go to WOT even if you have it floored from a dead stop--You do not get WOT til about 3600 RPM !! making your car a turd on the bottom end--A handheld cannot fix this real tuning can by making it go to WOT off idle
