Is there any way to switch C5 to DBC throttle ?
I have problems with DBW throttle with high boost and want to switch it to DBC
Is there any plug and play harness with stock 411 ECM will support this and keep the ABS and my dashboard working ?
Pro Mechanic
Gauges work except fuel. Think that's possible now through hp tuner.
No ABS
St. Jude Donor '13-'14-'15
On any C5 you can go to the "vehicle platform" section in your tune----Your car is called a "Y body" Then in the Y body platform list simply set the "electronic throttle section" to read NO-----
As far as the TPS is concerned you still may have to do some re wiring or re pinning to your ECM to make it work properly----
The ABS system and Traction Control system Both use the Throttle position sensor to control TQ---You need to make sure these systems are getting the correct information
