C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Will a Predator overwrite a Powerloader ?
Old Oct 24, 2002 | 03:25 PM
aces's Avatar
aces
Default Will a Predator overwrite a Powerloader ?
I have a 99 A4 that was loaded in 2001.
Will it a predator work ?
Do I or should I bother ? :confused:
Old Oct 24, 2002 | 04:30 PM
gojo's Avatar
gojo
Default Re: Will a Predator overwrite a Powerloader ? (aces)
Some Powerloaders are locked. But if yours is not it would be a bad thing to do. You would be adding to and not overwriting. You need to reflash to stock. Why do it? The program is probably as good as the Predator would be.
Old Oct 24, 2002 | 06:23 PM
aces's Avatar
aces
Default Re: Will a Predator overwrite a Powerloader ? (jfpilla)
How would I find out if it has been locked ?
Hmmmmmmm?
Old Oct 24, 2002 | 11:13 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Your car would need to be re-flashed to stock in order to be able to use the Predator. It cannot be used over an existing performance program.
Bob
To Will a Predator overwrite a Powerloader ?
