C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Pulling codes..
Old Oct 22, 2018 | 01:55 PM
04zjimc's Avatar
04zjimc
Default Pulling codes..
Can you pull codes even if they have been cleared? Either with a tech 2 or hptuners?
Old Oct 28, 2018 | 12:59 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Well yes and no------Typically you can get a "pending code" after one start cycle --But NO check engine light---- However to get a "history code" or a hard check engine light code it takes at least 3 driving cycles---meaning you must start the car run it up to operating temps--let it cool off to cold and start it agian---and on the 3rd cycle start you should get a hard code or a check engine light ( if there is something wrong)
