Have a 2002 C5 Coupe that is due for Spark Plugs .Have always wanted to try the E3 Plugs , just wondering if any one has any feedback on these Plugs as far as performance and reliability . Car has O.B.X. Longtubes and Varam Cold Intake .
There is NO HP advantage by gloing to these new crazy designed plugs--
Typically when someone changes to these miracle plugs and sees an increase in performanceit simply means that their old plugs were worn out or old so any NEW plug would have shown better performance--even a new stock set
The only thing that needs to be considered with plug choice is the "heat range" Even an engine with hdrs and a cam can use the stock plug heat range (NGK TR55) the only time you would need a COLDER plug such a a TR6 if you go to a boosted engine OR a high compression engine beyond 10-1 CR ratio
