Superchips experience?
https://superchips.com/shop/f5-gm-flashpaq
This is the podcast. It's very informative and the guys are fun to listen to.
http://www.underthehoodshow.com/
I'd probably give it a go for fun assuming the car is stock. Big thing I would double check is to make sure fuel trims are low.... if the tune adjusts the MAF calibration at all and it's way off, your wide open throttle tuning will be off for sure.
If you don't really like it, you can always sell it.
There should be a way to get the date of manufacture-----If the origial owner bought it in 2001 (lets say ) it is 17 years old and the newer models for the same car have many many new updates
2nd You did not say if your headers are long tubes OR shorty hdrs
You can use a handheld to tune shortys but not long tubes as LT's require much more special tuning than availiable on any handheld---It may work but you will be leaving lots of HP on the table and P/T drive ability will suffer
3rd I see you live in Calif Older Super chips devices only offer 87 oct tunes ans 93 oct tunes But in Calif we only have 91 oct premium So you will have to run it on the 87 tune and there will be little HP gains
The later model newer SChips do have 87-----91----and 93 oct tunes----If yours has a 91 tune then it is a newer one
Finally All 97 and newer Corvettes are already pretty well tuned bone stock . Sp don't expect miracles at best maybe 12-17 RWHP . Unlike a Camaro or Silverado where tuning can often net 20-30 RWHP
https://superchips.com/dashpaq_perfo...tuner_monitor/
