LS-1 Edit Codes
I need a little help loaded program this mouring and got three codes that i can not clear and non com with traction control,
codes are
844
1571
1644
I am going to disconnect battery then see but i do not know what a 844 is
somebody has to know what it is
Ls-1 Edit is :cool:
:cheers:
Press and hold options and then press Fuel 4 times while still holding the options button you must do this quickly. A message will appear saying "Diagonstics" then it will automatically read off the codes. Like....02-PCM(No codes)....03-BCM(No Codes)...ect. if there is a code it will look something like this 02-PCM (1052H) NOTICE THE H at the end of the code, That represents a code that has happened in HISTORY. If there is a C after the code it is CURRENT.
To clear the codes let it automatically cycle through the codes then it will come to (MANUAL DIAGNOSTICS) this is where you can clear codes. Use the options button to scroll forward and the TRIP to scroll backward find the code(s) to be erased like 02-PCM (2Codes). To erase this, press and hold the reset button until it says "NO CODES" There you have done it!!!. To exit the Diagonstic menu press the METRIC BUTTON!
Do those codes have a letter and numbers?
[Modified by jfpilla, 3:42 PM 11/7/2002]
My books did not have this code 844 in then, I knew about what it was but was not sure. Oh bye the way O YEA does not have any more codes set I fixed them all but 2 on left door it has a ground fault and still can not fix it.
