C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tech 2 comminication error
Old Jul 19, 2019 | 11:33 AM
SoAlVette's Avatar
SoAlVette
Default Tech 2 comminication error
Update - got it working, getting a bad connection at the OBDII port, had to hold it in. I will come up
with a fix.
Cannot connect my clone tech 2 to my car, keeps giving communication error???
I ran the self test and it passed, I checked my OBDII with my scanner and it worked.
When I hooked up my Tech 2 it will power up but tells me:
No communication with vehicle.
Check diagnostic link connector
Check ignition (On/Off)
Mike
Old Jul 19, 2019 | 02:18 PM
SoAlVette's Avatar
SoAlVette
Do the main test cables go bad or the OBDII adapters for the test cable?
Old Aug 5, 2019 | 09:13 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
GM hides the fuse to the OBD2 port on your cigarette lighter fuse Check that fuse It is not a good idea do use any aftermarket chargers or such on the cig lighter as it often blows the fuse and your OBD2 port wil not work--
Old Aug 17, 2019 | 02:58 AM
Jennitran's Avatar
Jennitran
4th Gear
Originally Posted by SoAlVette
Do the main test cables go bad or the OBDII adapters for the test cable?View the best obd2 scanner at Autoguysland in case you need.
Check the fuse because fuse goes bad, there will be no connection with the ecu. You also refer this link for your issue. Hope it helps.
https://mechanics.stackexchange.com/...-communicating
To Tech 2 comminication error
