C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tuning Question
Old Jul 23, 2019 | 06:18 AM
Geo50's Avatar
Geo50
Default Tuning Question
Good Morning everyone
I have a very simple question about tuned
Pcm. I had my 97 A4 coupe dyno'd a couple of months ago and now getting ready to start head cam and exhaust. My question is will the tune I have now be lost due to the battery being unhooked for a couple of days
Old Jul 23, 2019 | 09:28 AM
INSTIG8R's Avatar
INSTIG8R
No the tune won't be lost, but you will need to have it retuned when you finish the work
Old Jul 24, 2019 | 08:30 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
No it wont be lost if the battery dies because the tune is burned to the computer the same way GM does it, but it probably isnt set up to maintain stability for your aftermarket cam.
Old Sep 7, 2019 | 07:48 PM
whatyacallit's Avatar
whatyacallit
No but you won't want it anyway after making those changes. A new tune will be in order to make it run right and get the most out of the upgrades.
Old Sep 11, 2019 | 11:26 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
After a battery dis connect you can never loose your tune
However---The ECM has to relearn all the fuel trim data concerning altitde--air density and temperature-- as this is lost-- This is called "learning" Normally on a stockish bolt on engine the ECM will re learn the fuel trims after about 50-75 miles of normal driving--The more modded your engine is beyond bolt ons the longer it will take in miles
As mentioned if you do h s cam or LT headers you will need a retune
Old Sep 19, 2019 | 10:19 PM
whatyacallit
Once it's tuned you won't have to worry about a dead battery as the fuel trims should be close to 0. The point is that what tblu92 stated will be a non issue as the whole point of tuning is to get the fuel trims as close to 0 as possible.
Old Oct 8, 2019 | 11:20 PM
tblu92's Avatar
tblu92
Not al tuners will tune the LTFT fuel trims as the car needs to be driven on the street to get acccurate fuel trim readings Especially on a DYNO tune !! Most all dyno tuners run the engine in the gear ratio closets to 1:1 up to WOT and then only tune the timing and fuel only there---Unless they drove the car on the street thru all the gears at P/T they have not checked the LTFT's correctly-----
Tyocally a bolt on modded eng will have poaitive fuel trims due to the added airflow as the ECM during P/T is trying to correct the AFR back to STOIH 14.68:1
Any positive fuel trim at P/T "just before going to WOT" will be ADDED to your PE or WOR fueling as a lean safety----A negative fuel trim will always lock on "0" and never subtract fuel at WOT--again as a lean safety
PS Even a smal positive P/T fuel trim can make your WOT fuel pig rich say you have a +10% positive fuel trim JBWOT and you have commanded a WOT/PE fueling of 12.5-1 Then your ECM will add 10% to that Now making your WOT/PE fueling a pig rich 11.25 !!!!!
Old Oct 11, 2019 | 08:21 AM
whatyacallit
Yea, a dyno tune is nothing more than a "drag race" tune in my book unless the dyno has a brake to lock into all the different loads and rpm's necessary to get the p/t trims in line. (Most don't and it will cost significantly more) If the OP had a drag race only dedicated car maybe you could call it "tuned for it's purpose" but If it's a street driven car that was just "dyno tuned" then the OP never had a correct tune in the first place. (For it's intended purpose). I'm pretty much in agreement with what tblu92 stated above; although I wouldn't call a +10 part throttle fuel trim a "small positive fuel trim". I think he was just trying to make a point and I'm not trying to bust ***** here but wanted to clarify that for future readers. Ideally you don't want any positive fuel trim and as close to 0 as you can get on the negative fuel trims.
Old Oct 16, 2019 | 09:09 AM
piratepress's Avatar
piratepress
Wow, some great info on tuning in this thread.
To Tuning Question
