2000 ECM with a 1998 C5 engine
The confusing issue is that in the tune file the ECM "platform" says that it is both a Y-BODY and a GMT530 ??? I have never seen a tune file before where it lists 2 different platforms on the same tune---
Anyone ever run into this before and know a fix ? to get the trans to communicate with the ECM ? Could it be a faulty wiring harness ? which is a cheepo aftermarket one
PS I really don't even know what a GMT530 was used in---I am guessing it was a Mid Sized TRK or a SUV But I have never seen this combination on any 2000 vehicle----
THKS
THKS
My buddies 2000= GMT350
A 98 = NA as it does not even show that field under "system"
Odd issue.
You could try to change the system platform stuff and see what happens,
Lots of folks have changed C5 97/98 ecu to the later stuff with just gas gauge issues. But not trans issues.
Engine doesn’t care, the sensors are the same as you know.
Ive no doubt you will figure it out.
Ron
