C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Throttle body replacement causing issues
Old Oct 1, 2020 | 11:21 PM
SemDaMan's Avatar
SemDaMan
Default Throttle body replacement causing issues
Thought putting a new throttle body in my car would be a nice and relatively cheap way to gain a couple hp, so I went ahead and did that. It caused the issue of my check engine light, reduced power mode, traction control failure. I was wondering if this is just a problem with the ECU and with a hp tuner I could resolve this issue? ANY suggestions would be much appreciated.
Old Oct 5, 2020 | 09:33 AM
Gordy M's Avatar
Gordy M
Changing TB on a stock engine will give you an additional 0 HP. The stock TB flows about 750 CFM while the engine only flows slightly more than 6200 CFM.
With tuning you can make the new TB work but no HP gains
Old Oct 5, 2020 | 06:55 PM
bonesbrakr's Avatar
bonesbrakr
If you dont know why it isnt working then youre better off just putting the old one back on and being happy with a working car. Theres no mention of type of throttle body, codes or anything else.
To Throttle body replacement causing issues
