C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tech II not communicating
Old Mar 31, 2021 | 08:31 AM
CMC76's Avatar
CMC76
Default Tech II not communicating
At the dealer for my friend to turn off F45.
I'm not allowed in the service area. Go figure
But he just said it's not communicating with the module. i told him to look and see if it had already been disconnected, any other ideas if its connected and not communicating somewhere else?
Old Mar 31, 2021 | 12:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Make sure you have 12 volts at pin 16 at the DLC...a serial data issue can also cause no comms with all the modules ??...the dealer can’t figure this out ???
Old Mar 31, 2021 | 12:12 PM
CMC76's Avatar
CMC76
I left the car and told them to call me.
agreed, a dealer mechanic should not need me to research
Old Mar 31, 2021 | 12:13 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by cmc76
i left the car and told them to call me.
Agreed, a dealer mechanic should not need me to research
unbelievable !!!!!
Old Mar 31, 2021 | 10:43 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
GM hides the fuse to the 0BD2 port on the cigarette lighter circuit---Chances are if use use the cig lighter for device battery charging the fuse is burnt and it will not communicate
Old Mar 31, 2021 | 10:55 PM
CMC76's Avatar
CMC76
In the end he got it. All the f45 stuff is gone.
on to the abs and TCS codes.
also,, the brand new window switch I put in the other day that worked isn't working.
project for the weekend. Likely unrelated
To Tech II not communicating
