C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
engine temp on a dyno ?
Old Jun 11, 2021 | 10:29 AM
royal flush's Avatar
royal flush
Default engine temp on a dyno ?
what engine temp does a sharp tuner like to see while tuning car?
Old Jun 11, 2021 | 10:01 PM
Moved to C5 Scan and Tune section.
Old Jun 11, 2021 | 11:56 PM
CinciZ06's Avatar
CinciZ06
Your tuner will get your car to it's normal operating temp, and not seek to get it to any specific temp. There are functions of tuning that may need the car to be cold and idle up to temp with the scanner operating, etc. But overall, for what most people consider "tuning" the car needs to be at whatever temp it runs at when completely warm.
Old Jun 12, 2021 | 02:54 PM
aaronc7's Avatar
aaronc7
I want the car to be at normal operating Coolant, oil and intake air temp for tuning so it best replicates the conditions it will see on the street
Old Jun 18, 2021 | 04:48 AM
NSFW's Avatar
NSFW
The PCM has a table that adjusts timing based on coolant temp, and that table is all zero from 176-221 F, so anything in that range is probably fine.
I'd be more concerned with getting the oil temperature up to 170+ before doing full throttle pulls to the rev limiter.
To engine temp on a dyno ?
