Hi!!
does anyone know if i change from 5PSI to 7PSI on my supercharger,what do i have to change on the LS1edit program for better results?
thanks a lot!!!!!!!! :seeya
Depends, there is no magic formula, but here are a few things I would start with. 5 to 7 does not seem like it would require too much change.
increase PE-RPM multiplyer in the boosted range. Start high and lower until A/F is good.
To be on the safe side, you may also want to.
lower (by a few degrees in the high flow range) Spark Advance (airflow vs RMP). Start low and bump back up if you see no signs of knock.
i dont know if i am doing this things right,i already upload my .ls1 file to http://www.ls1edit.com it says 98 corvette ATI by TONY FELIX,can you help me to know if its right programmed??or if someone else can help me,i really apreciate it!!
Thanks a lot!! :seeya
instead of soliciting parameters from others (which may not work for you, or even hurt you), you should definitely get on the dyno to tune PE and WOT. You need AFR curves to base your adjustments on. That is the only way to do it right.
