C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Control module voltage
Old Nov 15, 2021 | 09:57 AM
AsphaltCaptain's Avatar
AsphaltCaptain
Default Control module voltage
I have a 2003 with control module voltage issue. Any ideas? I load tested everything and checked out. Optima red top.
File Type: hpt
File Type: hpl
Old Nov 15, 2021 | 06:17 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Which control module are you referring to ??…the car has many modules !!…what kind of voltage issues ??
Old Nov 16, 2021 | 07:19 AM
AsphaltCaptain
Oh the ECM Control module I believe. HP Tuners has limited access to the other system modules on a 2003 Corvette P01 ECM, the transmission TCM is integrated though. The alternator has a clutch and varies output during engine load for best performance and economy. Control Module voltage as seen in the Log file I posted, has me concerned because it's stable idling around 875rpm and TPS was 8.5-9% yet the control voltage is varying from 13.5- 11.80 volts!
Anyone familiar with the Corvette alternator causing an issue like this? Usually the logs with this PID in them show 13.5-13.9 volts.
Old Apr 19, 2022 | 08:39 PM
DavidAshman's Avatar
DavidAshman
3rd Gear
@AsphaltCaptain Perhaps I can help. Do you know the control module voltage PID number you are using? I have a C5 P59 ECM on the bench here with some debugging tools hooked up.
To Control module voltage
