C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tune Help
Old May 22, 2022 | 08:14 AM
ltnate's Avatar
ltnate
Default Tune Help
UPDATE: Added a gallon of coolant...guess I should've checked that first but after spending 8 months at the builder I assumed all fluids were topped off. Also shifting still doesn't seem quite right but I'm sure one of the experts will be able to look at this tune and tell me why. I added a log but couldn't really get on it as my passenger was a little scared so no real WOT stretches on the short drive. Thank you again.
Can someone look at this tune or make a recommendation on who is best to provide recommendations? my 03 has forged bottom end, mild BTR SC cam, long tube headers, built transmission, A&A SC w/3.6 pulley, 80lb injectors, and A&A fuel system. Initially I got the P1870 code because i swapped in 3.42, and now that's cleared up but I just don't trust the tune...maybe I'm being paranoid but if you've followed any of my posts on the Corvette forum this build has been an 8 month nightmare.
Test drove this newest tune yesterday in 85 degree weather, overheated twice in traffic, then wouldn't go below 240 degrees the rest of the way home (20 min). I also noticed the oil pressure seemed to be low but maybe not...only about 30 psi while cruising at 60 and not getting any higher when I accelerate. It was down to about 20psi when idling. Any help would be greatly appreciated. Thank youAttached Files
File Type: hpt
File Type: hpl
Old May 24, 2022 | 08:07 AM
ltnate's Avatar
ltnate
No recommendations?
Old May 25, 2022 | 06:15 PM
RonSSNova's Avatar
RonSSNova
I'm looking.
This is a MAF only tune.
You aren't logging near enough stuff.
Is there a wideband?
I don't see coolant above about 196 in that log. And oil pressure isn't present.
Try logging it with the channel config below.
Save it to C:\Documents\HP Tuners\VCM Scanner\Channel Configs
Then choose it from the scanner.
Hopefully you can figure that out, it can be confusing.
Ron
File Type: xml
Old May 26, 2022 | 12:29 PM
ltnate's Avatar
ltnate
Originally Posted by RonSSNova
I'm looking.
Ron
thank you...I'll do that tonight. Got it loaded but it's raining so I'll have to post a new log tomorrow or Saturday. Thank you again.
Old May 29, 2022 | 12:25 AM
RonSSNova's Avatar
RonSSNova
Cool!
Old Jun 9, 2022 | 10:40 PM
ltnate's Avatar
ltnate
Cool!
Weather hasn't been good enough to log but how does this tune look, especially the Trans settings? Thanks.
File Type: hpt
Old Aug 7, 2022 | 12:42 PM
ltnate's Avatar
ltnate
Updated Tune again...hoping someone can jump on and provide feedback. Car still won't start on first crank after sitting for a while but starts immediately after it's been driven. I've also started to be overwhelmed by gas fumes and after driving today it smells like its actually coming from driver rear tire. Thanks in advance for any feedback.
File Type: hpt
File Type: hpl
Old Aug 9, 2022 | 11:48 AM
wydopnthrtl's Avatar
wydopnthrtl
I once had a car that was nearly impossible to start but once running.. ran perfectly. Turned out to be a plugged fuel filter.
To Tune Help
