reduced engine power, no codes
i dont know what is the chicken and what is the egg. i was on the edge of loosing traction (like so very often) but never had problems with it before, torque by gear/rpm (cos3 here) are maxed out. no codes, except the p0102/3 because maf is gone. i believe both pulls are below the air limit (what was it again, 2.35 g/cyl?) and i had it up to 2.13 just the other day with no problems. besides hitting the limit should set p1514, right?
i was logging at 30hz only though, so all the numbers might be a bit out of phase. im cautious to do more puls, i could have some other problems like e.g. missfire (my tables go up to 6000rpm), although that should be setting codes as well. maybe my codes dont work?
what might be going on? any ideas before i rescale?
