C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
LS1 EDIT ?
Old Jan 30, 2003 | 03:09 AM
MC TORCH RED's Avatar
MC TORCH RED
Default LS1 EDIT ?
WITH MY MODS WILL AN LS1 EDIT TUNING GET ME INTO THE 12'S
Old Jan 30, 2003 | 05:20 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Re: LS1 EDIT ? (MC TORCH RED)
It should considering your so close already. IMO ls1 edit a worth every $$$ mod
Old Jan 31, 2003 | 01:51 AM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
LS1 edit should put you there. Your very close already...
:yesnod: :yesnod:
[Modified by NV MY C5, 8:25 AM 1/31/2003]
Old Jan 31, 2003 | 09:16 PM
Doc99SS's Avatar
Doc99SS
Maybe even a better set of tires would put you in the 12s.
What was your 60' time for the 13.002 sec run.
LS1Edit can help any car run better, but you will need a scanner also. You will not know what to change and by how much without a scanner.
:steering:
Old Jan 31, 2003 | 09:36 PM
MC TORCH RED
Default Re: LS1 EDIT ? (Doc99SS)
hey doc whats up 60ft times are always near 2.03 no spinning but can't crack 2.00 whith shock converter , i have a pt 2800 and 3.15 waiting in the garage. please advised on 60 ft. help.
[Modified by MC TORCH RED, 2:38 AM 2/1/2003]
Old Jan 31, 2003 | 09:40 PM
MC TORCH RED
also runnning on new run craps.....
Old Feb 3, 2003 | 08:29 PM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
You definitely need some stickier tires ! NITTO DRAGS 355R OR BFG DR. Your 60' time is to weak you need to pull a 1.90 or better . :steering:
Old Feb 3, 2003 | 09:39 PM
MC TORCH RED
Default Re: LS1 EDIT ? (JOHNNY P.)
do u think drag radials will do it. i am not spinning with run craps, leaving line at idle. when the track is sticky i never spinn off the line.
Old Feb 4, 2003 | 03:43 AM
JOHNNY P.'s Avatar
JOHNNY P.
IT'S all in your 60 ft time , you may not be spinning on your run flats but think about it. if you left the line at 2000 RPM vs. 4500-4900 rpm and not breaking up the tires on a DRAG RADIAL think about how much time you can pick up . your 60 ft times should be in the 1.80's or better with a consistent 1.70's 60 ft time on a drag radial . I manage to pull a consistent 1.74 60 ft time on a NITTO DRAG RADIAL 355R depending on track preperation if it breaks up I apply VHT to the tires and that always fixes the problem and it sounds awesome when the tires hook if you worried about appearance issues mount some drag radials on stock 17 inch rims and it's not very noticeable and that's the biggest size they come in . you will be amazed by a good set of DR'S . :steering:
[Modified by JOHNNY P., 8:47 AM 2/4/2003]
To LS1 EDIT ?
