C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
IPC Code, help Please
Old Mar 1, 2003 | 07:52 PM
maverickks's Avatar
maverickks
Default IPC Code, help Please
The last 2 times that I have checked the IPC codes through the DIC I have had the same one come up, P1571. I see this is for the ASR Desired Torque - C. Both times it has been a History code. I would like to know what is tripping this. Is there something I can correct so that I will not get this code or is this something I shouldn't worry about?
Thanks in advanced for your help.
:confused: :seeya
Jeff
[Modified by maverickks, 6:53 PM 3/1/2003]
Old Mar 1, 2003 | 08:19 PM
Kenny94945's Avatar
Kenny94945
Default Re: IPC Code, help Please (maverickks)
Hello,
I opened the service manual and it appears there are three components. The Power Train Control Module The Electronic Brake Traction Control Module and the Orange and Black Wire between them.
My thoughts:
1 - Ever have a battery leakage issue? If so check the PCM connectors.
2 - The sensors at the wheel are highly susceptible to debris. How about cleaning them up and re-sealing w/ some die electric grease.
The book seems to indicate an intermittent/ broken wire...if not a rub through causes this code.
I would personally start by pulling all the wheels and take a good look at the wiring in these areas.
Good hunting.
Old Mar 1, 2003 | 11:08 PM
maverickks's Avatar
maverickks
Default Re: IPC Code, help Please (Kenny94945)
Thank you for the information. I will start with the sensors along with the connections into the PCM. I haven't check into the leakage at the bottom. I have just looked from the top. I think that I will pull the battery out and do some checking to see if there is a problem. I am thinking that it would be very handy to have a set of those manuals!! Thanks again for the help.
:hurray:
Jeff
To IPC Code, help Please
