Headlights HELP!
:seeya
The T-84 exports look just like the stock headlights so a pic is necessary. However, the export assembly uses a single bulb in the middle vice 1 low and 1 high to either side.
You can pick up the assembly's and a plug and play harness from LAPD, they're in the Mall. You may also check the "for sale" area, bought mine off another member that was selling his.
Just noticed that this was in the SCAN and TUNE section - you might try GENERAL DISCUSSION to get more inputs.
later,
[Modified by THRAP 42, 1:04 PM 4/21/2003]
