C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help!!! Re-code the keys
Old May 7, 2003 | 01:15 PM
GrandMasterFlash's Avatar
GrandMasterFlash
Default Help!!! Re-code the keys
Hi
I have a little problem since my Incurance company wants me to re-program the keys, because I bought the car from germany (Cause they are cheaper than sweden). I called my GM service guy and he told me that I need to change the hole BCM or PCM (I don`t remeber wich one) and need 2 new key for the price of 1200$? Do I really need to do this. I thought the only thing you needed to do was re flash the computer and not to change the hole thing.
Is that correct or Is it the service guy that doesn´t know.
Please help :confused: :(
[Modified by GrandMasterFlash, 7:16 PM 5/7/2003]
Old May 7, 2003 | 05:10 PM
98GreenC5's Avatar
98GreenC5
Default Re: Help!!! Re-code the keys (GrandMasterFlash)
You should only have to get new cylinders for your ignition and doors,just have new keys made with the same resistance pellet as your present keys.
The bcm reads the resistance in the pellet and if it matches it (BCM) allows car to start.........No need for a PCM/BCM replacement. ( at least in US models,can't
believe exports would be different)
Have a great C5 day!
Dick
Old May 12, 2003 | 10:04 AM
siverman's Avatar
siverman
Default Re: Help!!! Re-code the keys (98GreenC5)
wow this is so cool I didnt understand anything
Old May 13, 2003 | 03:04 AM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
:bs That's nuts ! Look for another INSURANCE COMPANY ,if not listen to what 98GreenC5 mentioned . GOODLUCK ! :cheers:
Old May 13, 2003 | 01:19 PM
GrandMasterFlash
Default Re: Help!!! Re-code the keys (JOHNNY P.)
I´ll will never do business with that company again. Thanks 98GreenC5 for the info.
:seeya
To Help!!! Re-code the keys
