C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Ls1 Edit????
Old May 12, 2003 | 09:11 PM
Mordenkanen's Avatar
Mordenkanen
Default Ls1 Edit????
How do i set the trans to firm up the shifts? :confused:
Old May 13, 2003 | 07:50 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: Ls1 Edit???? (Mordenkanen)
Adjust force motor current. There's an example of this in the user manual.
Old May 14, 2003 | 10:45 PM
clancy's Avatar
clancy
To soften shifts go to Trans Calibration, A4 shift firmness, Positive Pressure vs Temperature. " Increase" the values in the table to soften the shifts. You can add a constant to the entire table or multiply by a %. Try 110% and judge the results. I found some trial error necessary. To make the shifts more firm decrease the values,play with those values until you get what you want. It will work :cheers: Start with 90% multipler to firm up the shifts.
To Ls1 Edit????
