C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
predator settings
Old Jun 3, 2003 | 04:51 AM
Jumper506's Avatar
Jumper506
Default predator settings
I installed the predator program and it worked great.I'm now changing my gears from 2.73 to 3.15.G.M is installing a new differential and reprograming the computer.When i get the car back can I reinstall the predator or doe's it have to be reprogrammed? :rolleyes:
Old Jun 7, 2003 | 04:03 AM
RWTD's Avatar
RWTD
Default Re: predator settings (Jumper506)
No, you do not want to reinstall the Predator if you have a pcm reflash, otherwise it will just void out your new uploaded calibration you just had done. Do not get your pcm reflashed, instead we need to get you a custom file made BEFORE you get your gears installed. I think you've already emailed me, so I will look for your email and make a correction on the reply I sent you, sir. If you get this before I send you the new email, please email me!
Sincerely...
