Need some help tuning.....
TEA S2 5.3 truck heads
232/238 111lsa comp XER
all the bolt ons
I am trying to get the car to idle good and eliminate the surging or bucking at low RPM/MPH <2k. What do I need to do with LS1edit?
Phillip
joel (Bink)
:cheers: :steering:
Phillip
http://forums.corvetteforum.com/zerothread?id=571549
Hope it works out...let us know
[Modified by SpinMonster, 10:56 AM 6/6/2003]
[Modified by SpinMonster, 11:02 AM 6/6/2003]
Idle Air
IAC PARK
IAC Gear
Ect...
[Modified by Phil97SVT, 9:37 AM 6/6/2003]
[Modified by SpinMonster, 6:32 PM 6/6/2003]
Idle Air
IAC PARK
IAC Gear
Ect...
idle air:guys set thses to 160% over defaults to smooth out the idle as a band aid but it prolonged the cruise control effect for me. I eventually reduced them back to stock as the car learned the changes.
IAC Tables: The motor in the TB will default to the setting you put here until the car reaches temp (in park and in gear) the one in gear allows for the air to be higher so it garrantees more air to operate things like the brakes until the car warms up....hence it causes the idle to hang even higher at first (cruise control effect).
IAC Follower: hangs the idle up after warm up for the same function
I know it seems like my above answer was 'beginnerish' but if you raise the idle in all tables, the IAC tables wont be starting off with the wrong value and prolonging the ability for the car to learn the proper settings. The raised idle in gear I suggested will negate the need for any adjustment in IAC gear since the car will have the vacuum it needs that you lost by moving your power band up so far as you did with this choice of cam. For an experiment with someone's stock car, lower the idle to 400 where you see it lope. You will see that the computer adds idle on deceleration to creat more air intake for the overly rich condition and alters this IAC function creating the cruise control effect. The conditions you experience happen with all cams but at different rpms due to the power band.....u cant use a near stock idle for a cam with a 2000+ to 6800+ power band for this reason.
[Modified by SpinMonster, 7:09 PM 6/6/2003]
Phillip
Phillip
You have a very low idle for a cam of that size.(or any over 224/224)
Timing: 27 Low 29 High Base +2
A/F: 12.75:1 per last dyno which I know is off
Compression: ~11.6:1 <== thinking about getting the heads milled again :)
Idle: starts @ 1050 and goes to 875
IAC: +.35
Idle Air: +4.5
Cam: 232/238 111lsa
1-get all ltft's to be neg.(by mult the entire MAF table by a percentage: if you have =8's on ftft's then mult the entire table by .92%
2-do power enrichment till you get all HO2's to be about .89-.91...below .89 is lean
3-advance the entire base timing curve and WOT curve by 5% (multiply table by 105%) then check for KR....if there is KR then pull it back at the rpm and load where it was pulling timing and then add 5% more timing to both curves. Eventually you will be at the max for all rpm's and loads. After you do this a few times start to advance by only 2%. After 5-6 times with this proceedure you will have a totally custom timing curve.
You will also notice this smooths out you idle too and your revs will be more effortless.
[Modified by SpinMonster, 9:56 PM 6/7/2003]
[Modified by SpinMonster, 9:58 PM 6/7/2003]
