C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
P0106 code
Old Jun 27, 2003 | 08:58 AM
RWhite's Avatar
RWhite
Default P0106 code after BIG cam install
Anybody get this code after a big cam install? I am assuming it is due to the cam characteristics causing unexpected vacuum/intake manifold pressure, which is different than what the computer is expecting.
[Modified by RWhite, 5:04 PM 7/8/2003]
Old Jul 2, 2003 | 01:34 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: P0106 code (RWhite)
Yes, I have seen it on auto's with large cams, when the MAP does seem to be performing find though. A few cases turned out to be a MAP, and several I have just disabled the code. Seems like some more research maybe needed on this. :)
Old Jul 2, 2003 | 04:14 PM
RWhite's Avatar
RWhite
Default Re: P0106 code (Godspeed)
My son is tuning the hot start stuff today. Probably a good day to try it out!
Old Jul 2, 2003 | 10:21 PM
RWhite's Avatar
RWhite
Jeremy, hot start is no longer a problem :D .
Many thanks!
To P0106 code
