Don't know if this is the same problem...but after some info from MAPMAN I took a closer look under the hood, around the MAF sensor and surrounding area. I found that the air filter cover wasn't sealing correctly, because one of the clamps was loose. I re-positioned the cover and clamped it down..... No more codes. Don't know if the problem is completely fixed...but no codes for the last few days.
