WHAT OTHER MODS SHOULD I PERFORM
I INSTALLED A K&N RAM AIR KIT.
WHAT IS THE NEXT STEP?
ANY IMPUT WOULD BE GREATLY APPRECIATED.
WHAT IS ALL THIS TALK ABOUT LS1 EDIT?
Re: WHAT OTHER MODS SHOULD I PERFORM (Z06TheKid)
THANKS FOR THE IMPUT
ANY RECOMMENDATION ON WHAT MANUFACTURER OF LONG TUBE HEADER.
HOW BENEFICIAL WOULD THE LS 1 MOD BE. ANY THOUGHTS OF WHAT TYPE OF POWER GAIN. ALSO IT SEEMS THERE ARE MANY PROBLEMS ENCOUNTERED WITH THE LS1 EDIT PROGRAM. WHAT ARE YOUR THOUGHTS?
Re: WHAT OTHER MODS SHOULD I PERFORM (SHOWTIME!)
IF HAVING THE CAPS LOCK ON BOTHERS YOU, DON'T BOTHER TO RESPOND!
YOU OBVIOUSLY HAVE NO GOOD INFO
Re: WHAT OTHER MODS SHOULD I PERFORM (NIC RYD)
Whats you're problem!I was asking a question because I did'nt understand.You're not very clear on you're explanation,I'm new to this.You must be miserable :boxing
Re: WHAT OTHER MODS SHOULD I PERFORM (Jumper506)
It is a known chat/forum/email etiquette thing...if you respond with all capitol letters you are YELLING...so if you don't mean to be YELLING then turn your computer keyboard CAPS-LOCK OFF.
Got it?
As far as mods....the LS1 mod as you refered to it, isn't really a mod, its a program and cable that you purchase that is used to alter (program) the PCMs default tuning. It allows great flexibility to alter your engines performance after adding mods that affect the stock tuning. It has a rather steep learning curve. You may want to got to the LS1 archives and read through some of the past descussions to get an idea if its the right thing for you. If it seems like to much you can always purchase the Predator which is the same type of product but with less flexibility than LS1Edit...
Re: WHAT OTHER MODS SHOULD I PERFORM (warpster)
Hey Man,I'm sorry for the misunderstanding,I did'nt realize you meant the writing in capital letters.I am getting my LS1 Edit professionally installed tomorrow,I just got it today.{he he]I thought you meant turning something off to do the programing.My tuner had me take off some bolt on's ,mod maf,mod iat.Said he would rather tune it first as close to stock as possible.Any input would be appreciated.Again sorry about the misunderstanding.Peace,John :cheers:
I did not know the protocol for these forums, I was not yelling, just trying to get some info.
Sorry for the misunderstanding and thanks for your info
