C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
EFI V6
Old Sep 15, 2003 | 08:12 PM
gojo's Avatar
gojo
Default EFI V6
It's available for download. :steering:
Old Sep 15, 2003 | 10:21 PM
Fasterproms's Avatar
0Fasterproms
Former Vendor
Default Re: EFI V6 (jfpilla)
Sweet I have been waiting for this!
Old Sep 18, 2003 | 05:52 PM
tpocock's Avatar
tpocock
Where? I do not find it on the Auto web site.
Old Sep 18, 2003 | 06:02 PM
gojo's Avatar
gojo
Default Re: EFI V6 (tpocock)
http://www.efilive.com/downloads/index.html
Old Sep 18, 2003 | 07:17 PM
tpocock's Avatar
tpocock
Thanks!
Old Sep 22, 2003 | 02:04 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Does anyone want to share the 'cliff notes' version of what's new for version 6? :cool:
Old Sep 22, 2003 | 01:57 PM
gojo's Avatar
gojo
Default Re: EFI V6 (BQuicksilver)
http://www.efilive.com/v6sneak.html
Go here.
Old Sep 22, 2003 | 02:15 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Thanks for the heads up :)
Old Sep 23, 2003 | 01:33 PM
gojo's Avatar
gojo
Default Re: EFI V6 (Flyin'Brian)
Thanks for the thanks and I really like the upgrade. It's :cool:
Old Sep 23, 2003 | 03:39 PM
tpocock's Avatar
tpocock
A lot slicker interface compared to V5, but -- I haven't got it loggin yet. It is not accepting my registration number. Still working on it.
Old Sep 23, 2003 | 07:52 PM
gojo's Avatar
gojo
The Vin has to be all caps. Copy the V5 license file and drop it into the V6 configuration folder.
Old Sep 23, 2003 | 08:29 PM
gojo's Avatar
gojo
From Paul.
"When you install a new version, EFILive will replace ALL the files that it originally installed (except the calc_pids.txt file - just made that change in build 21)
If you have added new files, they will be left untouched.
If you modify the default gauges - they will revert back to their install defaults when/if you install a new version.
If you create a custom dash and you do not want the gauges in your custom dash to revert back to their install defaults then you should save each customised gauge with a new name - preferably in a new theme folder (i.e. not in the Default theme folder)."
You also need to put in the Vin and License. I just copy the file to the new install. Save all your copies in a seperate folder.
Old Sep 23, 2003 | 09:05 PM
EFILive's Avatar
EFILive
The V5 license won't work in V6.
You are right about the caps - it does need to be all caps.
Also EFILive V6 only asks for the VIN if it is being used *prior* to ever having been connected to your car. It's just to give EFILive some indication of which PIDs to display. Once you make a connection to your car, EFILive will get the VIN from the car and use that instead.
Regards
Paul
Old Sep 23, 2003 | 10:40 PM
gojo's Avatar
gojo
Default Re: EFI V6 (EFILive)
Sorry Paul. I copied my license file in V6 the first install and copied it back each time. Too much tuning today.
Old Sep 28, 2003 | 07:32 PM
jfc33's Avatar
jfc33
Default Re: EFI V6 (jfpilla) V6 running question on cyl balance test?
EFI V6 - I have it running - the interface is better than v5...
anyone get the rpm/throttle settings to work in the dialog box for the cylinder balance test? The IAT ETC adjusters seem to have no effect. In other words, I can't set the throttle to hold an RPM between 900-1000 to run the test like you are supposed to be able to do?
any thoughts?
Old Sep 29, 2003 | 04:46 AM
gojo's Avatar
gojo
Default Re: EFI V6 (jfpilla) V6 running question on cyl balance test? (jfc33)
Mine worked. Try setting rpms by the gas pedal? I remember having trouble getting it to work. You should keep your curser on start and hold the pedal between 900-1000. Start when all the boxes turn green.
[Modified by jfpilla, 3:13 PM 9/29/2003]
Old Oct 1, 2003 | 08:50 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Great thread with good info. Thanks. :D
To EFI V6
Old Oct 10, 2003 | 09:30 PM
see5's Avatar
see5
.Regards
Paul
I sent the email request for update from 5>6?
Old Oct 10, 2003 | 11:43 PM
gojo's Avatar
gojo
Default Re: EFI V6 (see5)
Go here for it.
Old Oct 11, 2003 | 06:50 AM
see5's Avatar
see5
I have downloaded it but they want to give me and authorization to make it work? My 5 works great.
