C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help! code on s/c car
Old Sep 25, 2003 | 10:58 AM
scvett's Avatar
scvett
Default Help! code on s/c car
I just had a ati s/c with lg headers put on my 02 z06 I'm getting a po410 code. does anyone know what and how to fix it?
Thanks! :confused:
Old Sep 26, 2003 | 02:53 AM
1964VETTE's Avatar
1964VETTE
Default Re: Help! code on s/c car (scvett)
A test of the Secondary Air Injection system has failed. During the AIR test the AIR pump is activated injecting additional air into the exhaust stream. The oxygen sensors should detect this condition with their values falling below 222mv for at least 1.3sec. There should also be a corresponding change in the short term fuel trim. DTC PO410 is indicating that both banks (O2 sensors) did not respond correctly.
Make sure there are no kinked hoses or electrical problems that may have been created in the SAI system during the install.
Goodluck
LEC
Old Sep 26, 2003 | 10:24 AM
scvett's Avatar
scvett
LEC, thank you for the info. I reset the code and will see if it comes back the car seems to be running fine I will keep a watch on things. Thanks agin for the response. :cheers:
Old Sep 26, 2003 | 04:56 PM
David-F's Avatar
David-F
Check vaccumn lines, there is a vaccumn solenoid down by the air pump if you aren't getting vaccumn when you need to it will set this code you will also get this code if you have had a battery leak acid and damange vaccumn lines over by the battery.
David Fulcher
Old Sep 27, 2003 | 01:40 PM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
I had this code a while back. Although I do not have a s/c!
I had to get a new air pump, because there was water in it.
Do you have an aftermarket air box??
Old Sep 29, 2003 | 12:57 PM
scvett's Avatar
scvett
The code came back! I will have to check the vacum line to see if there is a problem, I dont seem to be loosing boost. If the sensor is not getting the right amount of air from the vacum line I'm not sure how to check or fix it? :confused:
Old Sep 29, 2003 | 05:46 PM
1964VETTE's Avatar
1964VETTE
scvette,
Your original exhaust manifolds had connections for the secondary air injection (SAI) plumbing. Your new headers should have had the same provisions. I assume that the SAI was completely reconnected???
LEC
Old Sep 30, 2003 | 09:18 AM
scvett's Avatar
scvett
Good question, I had More Performance in Charlotte N.C. install the headers I will need to ask them if there could be a problem with the conection. The headers are TPIS I would think they had the correct hardware with them to make the conection. Thanks LEC for the info.
To Help! code on s/c car
