What does this variable do? Is it for traction control? Lower = more sensitive, higher, less??
[Modified by 427CPE, 12:32 AM 9/29/2003]
Value is the Maximum torque delivered to the drivetrain. Therefore above this value Torque management kicks in.Intent is to protect the drivetrain from transient excessive force. Raising the value allows greater torque application. Max Value in LS1Edit is 639. Hope this helps some.
I've tuned several local Vette's and F-body's with Edit. If you have your own cable, I can show you several tricks on how to get around TM and abuse mode if you would like. I'm in Folsom as well.
